my consultant neef 24v DC 220Vac 4amp,
any model available with this ratings
Siga-CR Control Relay Module
Re: Siga-CR Control Relay Module
Noway,
I have also the same problem butI use this relay as interface between the SIGA CR and the 230VAC circuit,
It never burn until now.
please see the attached INFO.
- Fire Alarm Relay 6554 Series.pdf
- (74.52 KiB) Downloaded 669 times
Specifications:
24 Vdc @ 2A / 120 Vac @ 0.5 A
Relay type: Form C
Operating temperature range: 32 to 120 °F (0 to 49 °C)
Compatible electrical boxes North American 2-1/2 in (64 mm) deep 1-gang box Standard 4 in square box 1-1/2 in (38 mm) deep with 1-gang cover
PDF Attached
Specifications:
Relay type: Form C
PDF Attached
- SIGA-CR.pdf
- (123.44 KiB) Downloaded 1608 times
