Siga-CR Control Relay Module
peermoh80
Re: Siga-CR Control Relay Module
Post by peermoh80 »
my consultant neef 24v DC 220Vac 4amp,
any model available with this ratings
briac
Post by briac »
Noway,
I have also the same problem butI use this relay as interface between the SIGA CR and the 230VAC circuit,
It never burn until now.
please see the attached INFO.
Fire Alarm Relay 6554 Series.pdf
(74.52 KiB) Downloaded 671 times
Specifications:
24 Vdc @ 2A / 120 Vac @ 0.5 A
Relay type: Form C
Operating temperature range: 32 to 120 °F (0 to 49 °C)
Compatible electrical boxes North American 2-1/2 in (64 mm) deep 1-gang box Standard 4 in square box 1-1/2 in (38 mm) deep with 1-gang cover
PDF Attached
SIGA-CR.pdf
(123.44 KiB) Downloaded 1609 times
