WinPakPE - New Installation Problems
Re: WinPakPE - New Installation Problems
C:\Program Files\Microsoft SQL Server\MSSQL\Data
If your installation of WinpakPE is not working right. try running the attached registry file.
SQL/MSDE problems:
If it looks like MSDE is not installing during the first part of the installation you can manually install it.
Browse to the MSDE directory on the installation CD and install it, then run the installation CD
If there is a Version of SQL/MSDE installed on your PC before you start installing win-pakPE, uninstall it then manually install MSDEl, then install WINpak. I needed to do the install twice because it did not create the database the first time.
Quick Start-Wizard, will not work in XP
Search words: winpak winpakpe install problems problem
SQL/MSDE problems:
- Winpak install.reg
- Run this file to fix the registry for winpakPE installation
- (54.21 KiB) Downloaded 979 times
