Programming the NFC-50/100 - ECC-50/100
Manual-passwords-Quick install notes-Screen shots of web program
Is a 50 watt amp with one output.
Adding the 6 relay board will give you 4 evenly distributed speaker outputs
Adding the 50 watt board will make it a 100 watt panel and all 8 outputs will be available.
Both mount nicely in panel.
On startup clear NFC of all troubles.
power the panel up, connect batteries, resister out the panel to clear all troubles.
Connecting a notifier panel to the NFC via the ACS or 485 dataline will give you more control over which inputs from the FACP turn which speaker circuits on. the NFC will not send info back to the FACP with trouble status.
The easiest way to turn all the speakers on is to use CMD1 and the FACP's NAC circuit.
Troubles you can not clear/fix web into the NFC and check history, you may want to clear history there power cycle the panel.
Manual - Notifier FirstCommand NFC-50/100 Instruction Manual page 59
Web Browsing into the NFC to program.
change your computer to:
computer IP address: 169.254.3.5
computer Subnet mask: 255.255.0.0
panel http://169.254.3.3
Log In Password is 0000
before logging out check that the changes you made took.
log out so system can reboot, there will be three logouts
- Programming the NFC.doc
- This doc has screen shots of the web program for a NFC-50 with a 6 relay board and a 50 amp add on board
- (651 KiB) Downloaded 1854 times
- Notifier FirstCommand NFC-50-100 Instruction Manual.pdf
- (4.06 MiB) Downloaded 6576 times
