It is currently Wed Jan 17, 2018 9:25 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Fri Nov 05, 2010 9:10 pm
hello..
I have a problem w/ the QS4-CPU-2 that i can't retrieve data from the panel using RJ11 connector or PS6 rs232 this CPU is new, and its my first time to programmed QS4-CPU-2. Because i program before are QS4-CPU-1, QS1-CPU-1 is there a big different procedure on how program this CPU???
 Profile
PostPosted: Sat Nov 06, 2010 6:53 pm
If this is a new QS panel it may not have any database to retrieve.
QS4-CPU-1 or QS4-CPU-2, the 1 or 2 is the size of the front panel, can it hold 1 or 2 switch/led panels
no real different between the two panels
 Profile
PostPosted: Tue Nov 09, 2010 1:56 pm
What version Code is in Panel? 2.5??
1-) Assuming problem is not Wrong 9 pin serial port connector. IE--You cant use your ESt3 Rj-11 9 pin connector to load quickstart.
2-) Did you try 9600 baud rate? (instead of 38300k baud)
3-) On right com port in QS software?
4-) Are you using v2.5 (not v 1.8)
Sometimes, If I cant talk to panel and I tried everything, I will load 2.5 code loader. (Even if v 2.5 is already installed.) Just to get comms rollling.
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
