SP-6.1.1 Service Packs 2 3
BeJimmiepandy
SP 6 1 1 Service Packs 2 3
Post by BeJimmiepandy »
Yeah.. downloading the offline installers is easiest. Then just burn them to disks, and you are done and can use them over and over on other machines.
Secure Perfect is ending its life some, this is the last of the Service Packs you will see for it.
install sp2 then sp3
SP 6.1.1 Service Pack 2 SP611sp2
SP 6.1.1 Service Pack 3 SP611sp3
no need to copy and unzip, just OPEN and run from the download
SP2 & SP3 are helpful in getting clients to work
important, per tech support: when upgrading to Facility Commander from a Secure Perfect backup, SEcure Perfect needs service pack 3 for FC import to work.
SP 6.1.1 Service Pack 2 README File May 14, 2007
B. Updating Database
If this is an existing SP 6.1.1 system that is operational, and this computer is the database server, perform the following:
After applying the service pack, browse to the Secure Perfect folder.
Edit the file “SP611.bat”. Replace master with your “sa” password. Replace “computername” with your Database server name. Save the file and execute.
This needs to be done ONLY ONCE on the database server to apply a patch to the database
SP2 SP3 SP
SP611sp2README.rtf
(6.64 KiB) Downloaded 923 times
SP611sp3README.rtf
(16.07 KiB) Downloaded 894 times
SP-6.1.1 Service Packs 2 release notes
B. List of software fixes for Service Pack 1
1. Creating a region in a global edition fails with the error
“Object reference not set to an instance of an object”.
2. Secure Perfect crashes when intrusion zone or DI transactions are coming
in while the activity monitor is open.
3. Device redundancy fails.
4. On a converted database, badge downloads not always successful.
5. Allows the ability to separate the database and transaction log on creating a database.
6. Allows “-“ dashes and “_” underscores in computer names.
7. Allows for multibyte characters in badge and alarm printing.
8. Some invalid badge transactions come in as invalid pin.
9. Navigating between records in the micro form prompts for saving.
10. Corrected navigation between the alarm monitor and alarm graphics viewer.
11. Removed some columns in the intrusion zone form that were not necessary
12. Space bar or enter key created items in the alarm graphics viewer
13. Closing a video window still continued streaming video in the background.
14. Camera type in the camera form not displaying properly in Italian.
15. Micros sometimes losing communications after viewing the parameter information.
16. COM port settings in the micro form lost on saving.
17. Creates encryption alarms for the PXNPlus.
18. Secure Perfect Manager Service crashing.
19. Allows external reports to execute any application.
20. Allows playing of more than 16 cameras.
21. Client computers sometimes stops receiving alarms or badges.
22. Alarm graphics not displaying right mouse click menu.
23. History transactions on large system could sometimes cause the sytem to shutdown. Alarms that had microids larger than 2 digits would fail to be inserted and cause the system to shutdown.
24 Closing the manual control form stops displaying badges on the activity monitor.
25. If a server is connected to multiple DVRs, and they go into comm. loss at the same time, only one DVR Host comm. loss alarm is generated
26. Database archive is not deleting records properly from the DOHistory table.
27. Filtering badge activity on the activity monitor per facilities
28. Filtering alarm activity on the alarm monitor per facilities
29. Event Trigger form allows to select the same preset for multiple cameras
30. Message retries in the event of sporadic network errors
31. Improved performance for Global APB and Global T&A
32. Perform Motion Search on StoreSafe Pro II(CTII).
33. Manager Service memory constantly growing
34. Correct permissions on badge form
35. Allows the use of a badge issue and expiration date beyond 2013, up to 2099
36. Can create Global Edition databases on SQL Server 2000 and SQL Server 2005
37. Red line display in video window when using a StoreSafe Pro II(CTII).
38. DVRView display incorrectly when a dvmr fails over to a backup computer
39. Badge and Badge History reports can now filter with badge aliasing
40. Alarm or Badge History report can now filter by alarm or reader descriptions
41. Show date on the Clear Archive tab of the parameter form sometimes displays incorrect dates
SP-6.1.1 Service Packs 3 release notes
B. List of software fixes for Service Pack 3
1. Added support for Windows 2003 Service Pack 2 and Windows XP Service Pack 3.
2. Fixed the issue of slow network performance when adding a badge on a remote client via the WAN.
3. Fixed the issue of device redundancy occurring randomly.
4. Fixed the issue of names and descriptions being truncated in the history file when containing an apostrophe.
5. Fixed the issue of newly generated held open alarms not being reported in Alarm History report when filtered by the micro controller.
6. Fixed the issue of incorrect display of total time in time and attendance reports.
7. Fixed the issue on the Reader Form/Door Functions that if None is selected from the drop-down lists, an error is generated when trying to save the form.
8. Fixed the issue of video files recorded in SP 6.1.1 and saved as *.avi format do not display properly in the Microsoft Media Player.
9. Fixed the issue of the Micro Report displaying a Micro PXN+ as a Micro 6/s.
10. Fixed the issue of the CCTV on/off messages not being displayed in the Diagnostic Viewer if the application is not running.
11. Fixed the issue of not automatically creating the database during installation.
12. Fixed the issue of license failure on Windows 2003 server with SQL 2005 server when password policy is enforced.
