FCI 7100 reporting code for CID
My panel is set for option '6' which is the 4/2 transmission to the central station. I cannot find the option for CID. Can anyone help please?
Re: FCI 7100 reporting code for CID
main->config->dact->account options->comm format
in manual page 33
in manual page 33
I don't have the manual. I can get to the programming on the panel but do not have the 'option' number for CID. Right now it is '6' for 4/2 reporting. Can you help?
FCI 7100 Install manual
- 00-0447.pdf
- (270.77 KiB) Downloaded 774 times
I am very grateful. It helps me a lot. Thank you.
Now that the Contact ID option has been successfully changed (it is number '2') in the DACT programming I am looking to find out what numbers FCI is sending for their modules.
I know from Firelite that they add '159' to the device ID of a module, so a pull station set to 12 would send a '171' to the central station.
My FCI 7100 sends a '223' for a module set to '150' - is there also a standard offset to add? Anyone know?
Issue solved. Thank you. This panel does not send individual device numbers
