Silent Knight SK-5207 Programming 4/2 SIA
The sk-5207 can do 4/2 and SIA
TG7 can do 4/2 and SIA
Starlink 4/2 only no SIA
If you are putting a TG7 or Starlink you will need to send your CS the right report codes
attached are PDFs with the report codes for 4/2 and SIA
SIA
With SIA most the codes will come in right, but some will need to be fixed
as an example NAC 1 trouble will display in the CS account history as
ET32 - EXPANSION TROUBLE/COMM LOST 32
you will want it to display as
ET32 - NAC 1 Trouble
Below is a list Of SIA messages you should change
if you receive one of these SIA report codes no one will know what it is.
look at bthe attached doc to see want it does send.
ER0 Dialer back to normal.
ER32-35 Notification device 1-4 back to normal.
ER38 Circuit ground earth fault removed.
ER39 Power earth ground fault removed.
ET0 Dialer trouble.
ET17-23 Annunciator 1-7 back to normal.
ET32-35 Notification device 1-4 trouble.
ET38 Earth ground fault to circuit ground.
ET39 Earth ground fault to power.
SK 4+2 Format
1-16 ALARM/SUPV
20-26 RESTORE ZONE 10-16
30 Dialer Test, Walk Test, Fire Drill
31 Phone Line 1 Trouble
32 Phone Line 2 Trouble
33 Expansion Trouble
35 Phone Line 1 Restore
36 Phone Line 2 Restore
37 Expansion Restore
39 Data Lost
50 Disable Zone
60 AC Lost OR TROUBLE ZONE 10
61-68 TROUBLE ZONE 1-8 11-16
69 TROUBLE ZONE 9 OR LOW BATTERY
70 AC Restore
71-78 RESTORE ZONE 1-8
79 Battery Restore OR ZONE 9 RESTORE
91 Reset Alarm
SK-5207 MANUAL.pdf
(1.86 MiB) Downloaded 1150 times
SK-5207 4-2 format.pdf
(101.21 KiB) Downloaded 1434 times
SK-5207 SIA CODE.pdf
(135.49 KiB) Downloaded 1223 times
