*EST3-SDU - Lost password/Recover project/get old SDU's back
download this file
pdxview.zip
unzip
open DBviewer.exe
program menu->open file
find project.db then open
actions -> find -> hit "find"
THERE IT IS
** if you have problems with DBviewer.exe
** go to this site http://scalabium.com/ it is the latest PDviewer ** run as admin
If you have a SDU that you do not have a Password for or a SDU that needs to be recover from a old PC or directory.
Will also work with the EST2 sdu's
note: It seems like the term SDU can mean the EST3 program or the Project. (The SDU is the project for this post)
Overview-You will need to make a new project, save it, delete the version directory and copy the old project into it.
1 - Lost password for Exported SDUs:
The exported SDU file ie. factory1.SDU is little more then a Zip file.
Change the SDU file to -> factory1.ZIP, now just unzip the file. it will look like factory1_01_01_01
Now rename the SDU directory Factory1_01_01_01 to 01_00_00
2 - Setup the SDU project that is in need:
Open the EST3 program -> project-> new-> LOST_PROJECT -> save -> close
The password you use will be the old SDU's new password
You will probably need to do a (save as) to match the old sdu version
ie. old sdu 01.01.01 -> new sdu 01.01.01
3- Move the Old SDU program into the newly created directory
Now find the directory project\LOST_PROJECT\01_00_00
Delete it - 01_00_00
Move the renamed/lost SDU into project\LOST_PROJECT\
The only thing to keep in mind:The old and new SDU version directory names need to be the same 01_00_00 ->99_99_99
icyangle
Re: *EST3-SDU - Lost password/Recover project/get old SDU's
Post by icyangle »
yeah,I did those steps just by chance,and succeeded.
shashishashu
Post by shashishashu »
You can send me the backup of your project. I will provide you the password.
BHRAGU
Post by BHRAGU »
There is one more way to recover the password from the exported project backup.Refer the attached file.
SDU password recovry.docx
(251.25 KiB) Downloaded 3574 times
shashishashu
Created a small tool for get lost password. Download from this link-
http://www.send6.com/members/storageUse ... inID=76962
Username & Password - shashish_uploads
dougncin
Post by dougncin »
I'm having trouble getting password for this SDU file. I copied the Progect.db from it. I can find the password on other SDUs but this one I cannot.
Any help will be great
BLOCK_D 01.06.02D € €3053B4D600000006€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€UTSWM_NB01.01.01FIRE €</ƒY‘€ €4DEA159300000023€
Nirujan
Post by Nirujan »
dougncin wrote:I'm having trouble getting password for this SDU file. I copied the Progect.db from it. I can find the password on other SDUs but this one I cannot.
Your Password would be FIRE TRY IT.
dougncin
Post by dougncin »
FIRE didn't work.
did you try pdxview.zip?
try down loading the new version http://scalabium.com/ it is the latest PDviewer ** run as admin
Nirujan
Post by Nirujan »
if you can send me your sdu file i will try .
