2 year project - Rules - PAS
1. C O M M A N D L I S T
2. O N E T O O N E
3. D U C T
4. E L E V A T O R
5. P A S
6. AND STATEMENTS
7. BAY TOWER HANDICAP GUEST RM SMKS/CO
8. WTR FRONT TOWER GUEST RM SMKS
9. L E D
10. S W I T C H E S
11. AMPS transfer
[PANEL SILENCE SWITCH]
MONITOR '*PANEL_SILENCE_SWITCH*': +TS 'NODE_7_JIM_ADT';
[STARTUP RULE FOR AUDIO]
STUP: DELAY 5,
MSGON 'Default_Normal_01_08' TO 'Ch_Gen_01_08',
AMPON 'ZA20_AMP' TO 'Ch_Gen_01_08';
[ALARM SILENCE]
ALARMSILENCE:
ACTIVATE 'Command_Alarm_Silence',
DELAY 0,
AMPOFF 'ZA20_AMP' TO 'Ch_Evac_01_08';
[command-ALARM SILENCE]
Activation CMDLIST 'Command_Alarm_Silence':
OFF -SET AUDIBLE 'VALET_HORNSTROBE1',
OFF -SET SUP 'ELEV_CARS_SPK*',
Off -SET SUP '*SPEAKER*';
[RESET STAGE ONE]
R1: DELAY 0,
ON NSO 'RESET_3_MINUTE_TIMER';
[RETAIL CORR WAND DOOR SMOKES]
ALARM 'RETAIL_BUFFET_WAND_DOOR_SMK*' : ON NSO 'RETAIL_CORRIDOR_WAND_DOOR';
{----------- DRILL ALL CALL SWITCH PROGRAMMED FOR PAS -----------------------------------}
[SYSTEM FUNCTION 3 RESPONSE]
SMON 'System_Function_3_Response_00_00' :
DELAY 0,
OFF -LOW NSO 'POSITIVE_ALARM_LITE*',
Activate 'PAS_ACKNOWLEDGE_1',
DELAY 0,
+ON 'ON_3_MINUTE_TIMER',
DELAY 1,
+OFF 'ON_3_MINUTE_TIMER',
AMPOFF -LOW 'ZA20_AMP' TO 'Ch_Evac_01_08';
{************** C O M M A N D L I S T ******************************}
[command-Lorise Total Evac] Activation CMDLIST 'Lorise_Total_Evac'
[command-Lorise Recall to Main]
[command-Lorise Recall to Alt]
[command-Lorise Total Evac HIGH] AND
[command-Lorise Recall to Main HIGH]
[command-Lorise Recall to Alt HIGH]
[COMMAND-BAY ALL LVL] STAIR/DIALER/MUTE/RECALL MAIN/ELEV
[COMMAND-WATERFRT ALL LVL] STAIR/DIALER/MUTE/RECALL MAIN/ELEV
[COMMAND-ALL OUTPUTS OFF -SET]
[COMMAND-PAS OFF] Activation CMDLIST 'PAS_ACKNOWLEDGE_1'
{************** LORISE PAS - COMMAND LIST ******************************}
Activation CMDLIST 'Lorise_Total_Evac':
DELAY 0,
ON -LOW NSO 'AMPS_Activate_Relay*',
DELAY 2,
ON -LOW NSO '*LORISE_SMK_PURGE*',
ON -LOW NSO 'BAY_STAIR_PRESS*', {STAIR PRESSURIZATION }
ON -LOW NSO 'BUFFET_GAS_VALVE*',
ON -LOW NSO 'RETAIL_CORRIDOR_WAND_DOOR*',
ON -LOW NSO 'WTR_FRT_*_ELV_DAMPER*',
ON -LOW SUP 'ELEV_CARS_SPK*',
ON -LOW '*Lorise_*_PAS_LVL_ALL*',
ON -LOW NSO '*Harrahs*PAS_LVL_ALL*';
Activation CMDLIST 'Lorise_Recall_to_Main':
DELAY 0,
ON -LOW NSO 'BAY_*_MAIN_RECALL',
ON -LOW NSO 'BUFFET_ELEV_RECALL_MAIN*',
ON -LOW NSO 'POOL_ELEV_RECALL_MAIN',
ON -LOW NSO 'WTR_FRT_PUBLIC_ELEV_RECALL_MAIN*',
ON -LOW NSO 'WTR_FRT_SVC_ELEV_RECALL_MAIN*',
ON -LOW NSO '*ELEV*PAS_LVL_MAIN*';
Activation CMDLIST 'Lorise_Recall_to_Alt':
DELAY 0,
ON -LOW NSO 'BAY_*_ALT_RECALL',
ON -LOW NSO 'BUFFET_ELEV_RECALL_ALT*',
ON -LOW NSO 'POOL_ELEV_RECALL_ALT',
ON -LOW NSO 'WTR_FRT_PUBLIC_ELEV_RECALL_ALT*',
ON -LOW NSO 'WTR_FRT_SVC_ELEV_RECALL_ALT*',
ON -LOW NSO '*ELEV*PAS_LVL_ALT*';
{------------------- LORISE ON HIGH FOR AND'S---------------------------}
Activation CMDLIST 'Lorise_Total_Evac_HIGH':
DELAY 0,
ON -HIGH NSO 'AMPS_Activate_Relay*',
DELAY 2,
ON -HIGH NSO '*LORISE_SMK_PURGE*',
ON -HIGH NSO 'BAY_STAIR_PRESS*',
ON -HIGH NSO 'BUFFET_GAS_VALVE*',
ON -HIGH NSO 'RETAIL_CORRIDOR_WAND_DOOR*',
ON -HIGH NSO 'WTR_FRT_*_ELV_DAMPER*',
ON -HIGH SUP 'ELEV_CARS_SPK*',
ON -HIGH NSO '*Harrahs*PAS_LVL_ALL*',
ON -HIGH NSO '*Lorise_*_PAS_LVL_ALL*',
ON -HIGH SUP '*Lorise_*_PAS_LVL_ALL*',
ON -HIGH VISIBLE '*Lorise_*_PAS_LVL_ALL*';
Activation CMDLIST 'Lorise_Recall_to_Main_HIGH':
DELAY 0,
ON -HIGH NSO 'BAY_*_MAIN_RECALL',
ON -HIGH NSO 'BUFFET_ELEV_RECALL_MAIN*',
ON -HIGH NSO 'POOL_ELEV_RECALL_MAIN',
ON -HIGH NSO 'WTR_FRT_PUBLIC_ELEV_RECALL_MAIN*',
ON -HIGH NSO 'WTR_FRT_SVC_ELEV_RECALL_MAIN*',
ON -HIGH NSO '*ELEV*PAS_LVL_MAIN*';
Activation CMDLIST 'Lorise_Recall_to_Alt_HIGH':
DELAY 0,
ON -HIGH NSO 'BAY_*_ALT_RECALL',
ON -HIGH NSO 'BUFFET_ELEV_RECALL_ALT*',
ON -HIGH NSO 'POOL_ELEV_RECALL_ALT',
ON -HIGH NSO 'WTR_FRT_PUBLIC_ELEV_RECALL_ALT*',
ON -HIGH NSO 'WTR_FRT_SVC_ELEV_RECALL_ALT*',
ON -HIGH NSO '*ELEV*PAS_LVL_ALT*';
Activation CMDLIST 'BAY_TWR_HI_RISE':
ON -LOW SUP 'STR_1_SPEAKER_BAY',
ON -LOW SUP 'STR_2_SPEAKER_BAY',
ON -LOW SUP 'ELEV_CARS_SPK_BAY',
ON -LOW VISIBLE 'STR_*_STROBE_BAY',
ON -LOW NSO 'BAY_SVC_MAIN_RECALL',
ON -LOW NSO 'BAY_PUBLIC_MAIN_RECALL',
ON -LOW NSO '*Harrahs*_PAS_LVL_ALL*';
Activation CMDLIST 'WATERFRT_TWR_HI_RISE':
ON -LOW SUP 'STR_1_SPEAKER_WF*',
ON -LOW SUP 'STR_2_SPEAKER_WF*',
ON -LOW SUP 'ELEV_CARS_SPK_WTR_FRT_PASS*',
ON -LOW SUP 'ELEV_CARS_SPK_WTR_FRT_SVC*',
ON -LOW VISIBLE 'STR_*_STROBE_WF*',
{--------------- TURNS ALL OUTPUTS OFF ((SET)), USED FOR SWITCHES -------------------}
Activation CMDLIST 'SET_OFF' :
MSGOFF -SET 'Default_Evac_01_08' TO 'Ch_Evac_01_08',
AMPOFF -SET '*' to 'Ch_Evac_01_08',
OFF -SET SUP '*',
OFF -SET VISIBLE '*',
OFF -SET NSO '*';
[COMMAND-PAS OFF]
Activation CMDLIST 'PAS_ACKNOWLEDGE_1':
OFF -LOW SUP 'BAY_*_LVL*_SPEAKER*',
OFF -LOW SUP 'STR*',
OFF -LOW SUP 'ELEV_CARS_SPK*',
OFF -LOW VISIBLE 'BAY_*_LVL*_STROBE*',
OFF -LOW VISIBLE 'STR*',
OFF -LOW VISIBLE 'BAY_GUESTRM_*_STROBE_HANDI_LVL*',
OFF -LOW NSO 'WTR_FRT_*_ELEV_RECALL*',
OFF -LOW NSO 'BUFFET_ELEV_RECALL*',
OFF -LOW NSO 'POOL_ELEV_RECALL*',
OFF -LOW NSO 'POOL_ELV*',
OFF -LOW NSO 'RETAIL_CORRIDOR_WAND_DOOR*',
OFF -LOW NSO 'BUFFET_ELEV_SHUNT',
OFF -LOW NSO 'BUFFET_GAS_VALVE*',
OFF -LOW NSO 'BAY_*_RECALL*',
OFF -LOW NSO 'BAY_STAIR_PRESS*',
OFF -LOW NSO '*LORISE_SMK_PURGE*',
OFF -LOW NSO 'AMPS_Activate_Relay*',
OFF -LOW NSO 'WTR_FRONT*',
OFF -LOW NSO 'BAY_WTR_FRT_LVL*_DOORS*',
{OFF -LOW NSO 'WTR_FRONT_*_Fl_DAMPER_LVL*',}
OFF -LOW NSO 'WTR_FRONT_RM_*_GEN_BEDSHAKE_LVL*',
OFF -LOW NSO 'WTR_FRT_*_ELV_DAMPER*',
OFF -LOW VISIBLE '*_PAS_LVL_*',
OFF -LOW SUP '*_PAS_LVL_*',
OFF -LOW NSO '*_PAS_LVL_*';
{************* O N E T O O N E ******************************}
[MARINA DUCT 15.9.149] ALARM '*MARINA*DUCT*@*': ON NSO '*@15.9.149*'; {DUCT MARINA all floors}
[2.2.001] ALARM '*@2.2.001*': ON NSO '*@2.2.129*'; {MUA1 SUPPLY DUCT PUMP RM BEHIND FCC}
[2.2.002] ALARM '*@2.2.002*': ON NSO '*@2.2.166*'; {AHU 201 SUPPLY DUCT McCormick&Schmick's}
[2.2.003] ALARM '*@2.2.003*': ON NSO '*@2.2.166*'; {P-1 AHU201 DUCT McCormick&Schmick & POKER}
[2.2.126] ALARM '*@2.2.126*': ON NSO '*@2.2.129*';
[2.2.147] ALARM '*@2.2.147*': ON NSO '*Harrahs_DIALER_PAS_LVL_ALL*'; {GARAGE FIRE ALARM}
{[7.4.004] ALARM '*@7.4.004*': ON NSO '*@16.2.193*'; {AH1 - STOP}}
[14.3.016] ALARM '*14.3.016*': ON NSO '*@14.3.122*'; {DUCTMARINA SUPPLY 3RD FL RF2}
[14.3.019] ALARM '*@14.3.019*': ON NSO '*@23.2.140*'; {SMOKEMARINA 3RD AHU1 SUPPLY}
[15.9.011] ALARM '*@15.9.011*': ON NSO '*@14.3.120*', {DUCTMARINA AHU3 SUPPLY ROOF}
ON NSO '*@14.3.122*',
ON NSO '*@14.3.123*',
ON NSO '*@14.3.128*',
ON NSO '*@14.3.129*';
[16.2.001] ALARM '*@16.2.001*': ON NSO '*@16.2.193*', {DUCTAHU #1 SUPPLY}
ON NSO '*@4.2.412*'; {7 STAR DAMPERS}
[16.2.002] ALARM '*@16.2.002*': ON NSO '*@16.2.198*'; {DUCTAHU#2 SUPPLY, 3RD ATRIUM MECH RM 302}
[16.2.004] ALARM '*@16.2.004*': ON NSO '*@16.2.200*'; {DUCTAHU #3 SUPPLY, 3RD ATRUM MECH RM 302}
[16.4.001] ALARM '*@16.4.001*': ON NSO '*@16.2.168*'; {DUCT:AH #6 MER #203}
[16.4.002] ALARM '*@16.4.002*': ON NSO '*@16.2.162*'; {DUCT:AH #7 MER #204}
[16.4.003] ALARM '*@16.4.003*': ON NSO '*@16.2.155*',
ON NSO '*@16.2.156*'; {SMOKE:3rd fl mech rm,above fans/air handler}
[22.2.151] ALARM '*@22.2.151*': ON NSO '*@22.2.136*',
ON NSO '*@22.2.141*'; {SMOKEHARBOR 16TH, elev shaft1 S7 & S8}
[22.3.253] ALARM '*@22.3.253*': ON NSO '*@22.2.136*',
ON NSO '*@22.2.141*'; {SMOKE HARBOR TOP service elev SHAFT-RECALLS ELEVs}
[22.3.427] ALARM '*@22.3.427*': ON NSO '*@22.2.136*',
ON NSO '*@22.2.141*'; {P1 FLOWHarbor service elev penthse}
[23.2.001] ALARM '*@23.2.001*': ON NSO '*@23.2.141*'; {DUCTAHU 11 RETURN}
[23.2.002] ALARM '*@23.2.002*': OFF NSO '*@23.2.140*'; {**0FF** - DUCTAHU 10 RETURN}
[23.2.003] ALARM '*@23.2.003*': ON NSO '*@23.2.144*'; {DUCTAHU 11 SUPPLY}
[23.2.004] ALARM '*@23.2.004*': ON NSO '*@23.2.141*'; {DUCTAHU 10 SUPPLY}
[23.2.005] ALARM '*@23.2.005*': ON NSO '*@23.2.189*',
ON NSO '*@23.2.191*'; {SMOKEGarage 2nd flr cross over}
[23.2.145] ALARM '*@23.2.145*': ON NSO '*@23.2.144*'; {P1 PULLHALL BY HARD COUNT/ARMORD CAR BAY}
[23.2.146] ALARM '*@23.2.146*': ON NSO '*@23.2.144*'; {P1 PULLMANTRAP1 LEFT SIDE ENT FROM CASNO}
[24.3.008] ALARM '*@24.3.008*': ON NSO '*@24.2.148*'; {P1 DUCT AHU BUU 1 SUPPLY MER #202}
[25.2.005] ALARM '*@25.2.005*': ON NSO '*@25.2.127*'; {DUCTFC303, 2ND FL MEZZ MECH RM}
[25.2.007] ALARM '*@25.2.007*': ON NSO '*@25.2.136*',
ON NSO '*@25.2.134*'; {DUCTSUPPLY M310 2ND, MECH ROOM MEZZ}
[25.2.008] ALARM '*@25.2.008*': OFF NSO '*@25.2.134*'; {P1 DUCT RETURN M310 2ND, MECH ROOM MEZZ}
[25.2.009] ALARM '*@25.2.009*': ON NSO '*@25.2.142*',
ON NSO '*@25.2.144*'; {DUCTSUPPLY M308 2ND, MECH ROOM MEZZ }
[25.2.018] ALARM '*@25.2.018*': OFF NSO '*@25.2.142*'; {P1 DUCT RETURN M308 MECH ROOM MEZZ}
[25.2.019] ALARM '*@25.2.019*': ON NSO '*@02.4.153*'; {DUCTAHU FR4 SUPPLY, MER #207}
[25.2.021] ALARM '*@25.2.021*': ON NSO '*@25.2.186*'; {DUCTAHU FR3 SUPPLY, MER #207,HI LIMIT}
[25.2.023] ALARM '*@25.2.023*': ON NSO '*@02.4.151*'; {DUCTAHU FR2 SUPPLY, ARM}
[25.2.025] ALARM '*@25.2.025*': ON NSO '*@02.4.149*'; {DUCTAHU FR1 SUPPLY, ARM}
[25.3.003] ALARM '*@25.3.003*': ON NSO '*@16.2.165*',
ON NSO '*@25.2.188*'; {SMOKECASINO HI LIMIT Freight Elev Shaft }
[25.3.005] ALARM '*@25.3.005*': ON NSO '*@16.2.165*',
ON NSO '*@25.2.188*'; {SMOKECASINO HI LMT 2nd Freight elv lobby}
[26.2.001] ALARM '*@26.2.001*': ON NSO '*@27.2.191*',
ON NSO '*@27.2.192*'; {P1 RETURN DUCT DETECTOR REFLECTIONS POKER}
[26.2.003] ALARM '*@26.2.003*': ON NSO '*@27.2.191*',
ON NSO '*@27.2.192*'; {DUCTSUPPLY REFLECTIONS POKER}
[26.2.188] ALARM '*@26.2.188*': ON NSO '*@26.2.200*',
ON NSO '*@26.2.201*',
ON NSO '*@26.2.202*'; {P1 ANSULCORNER GRILLE}
[26.2.189] ALARM '*@26.2.189*': ON NSO '*@26.2.203*',
ON NSO '*@26.2.204*',
ON NSO '*@26.2.205*'; {SUPVHOOD WASH DOWN SYSTEM CORNER GRILLE}
[27.2.001] ALARM '*@27.2.001*': ON NSO '*@27.2.215*',
ON NSO '*@27.2.186*'; {DUCT5A SUPPLY, FLORENTINO}
[27.2.002] ALARM '*@27.2.002*': ON NSO '*@27.2.215*',
ON NSO '*@27.2.187*'; {DUCT5B SUPPLY, FLORENTINO}
[27.2.003] ALARM '*@27.2.003*': ON NSO '*@27.2.191*',
ON NSO '*@27.2.192*'; {DUCTAHU6 SUPPLY, 2ND FL STEAKHOUSE}
[27.2.004] ALARM '*@27.2.004*': ON NSO '*@27.2.217*',
ON NSO '*@27.2.218*'; {DUCTMUA101B SUPPLY, 2ND FL STEAKHOUSE}
[27.2.005] ALARM '*@27.2.005*': ON NSO '*@27.2.217*',
ON NSO '*@27.2.218*'; {DUCTMUA101B SUPPLY,2ND FL STEAKHOUSE}
[27.2.006] ALARM '*@27.2.006*': ON NSO '*@27.2.217*',
ON NSO '*@27.2.218*'; {DUCTMUA #101A SUPPLY, 2ND FL STEAKHOUSE}
[27.2.007] ALARM '*@27.2.007*': ON NSO '*@27.2.221*',
ON NSO '*@27.2.220*'; {DUCTHARBOR ROOF ABOVE TELE SERVICES}
[27.2.184] ALARM '*@27.2.184*': ON NSO '*@27.2.206*'; {P1 ANSULFIORENTINO'S 2ND,C line gas side}
[27.2.198] ALARM '*@27.2.198*': ON NSO '*@27.2.204*',
ON NSO '*@27.2.205*'; {P1 ANSULSTEAKHOUSE 2nd, MAIN COOK LINE}
[27.2.201] ALARM '*@27.2.201*': ON NSO '*@27.2.207*'; {P1 ANSULSTEAKHOUSE BRAISERKETTLE LINE}
[27.2.209] ALARM '*@27.2.209*': ON NSO '*@27.2.214*'; {P1 ANSULSTEAKHOUSE MAIN KITCHEN COOKLINE}
[27.2.210] ALARM '*@27.2.210*': ON NSO '*@27.2.205*'; {P1 ANSULSTEAKHSE LINE,PANTRY,ROTARY HOOD}
[27.4.005] ALARM '*@27.4.005*': ON NSO '*@22.2.136*',
ON NSO '*@22.2.141*'; {SMOKE3rd fl HARBOR Service elev lobby 7 & 8}
[27.4.006] ALARM '*@27.4.006*': ON NSO '*@22.2.136*',
ON NSO '*@22.2.141*'; {SMOKE2nd HARBOR Service elev lobby 7 & 8}
[27.5.004] ALARM '*@27.5.004*': ON NSO '*@27.2.130*',
ON NSO '*@27.2.170*',
ON NSO '*@27.2.172*'; {DUCT2ND, CAPTAIN'S QUARTERS, HARBOR CLUB}
{************** D U C T ******************************}
[DUCT-AHU401-508]
ALARM 'LORISE_AHU<N:401,404-405,500-507,508>_PAS_LVL*' :
ON -LOW NSO 'AHU_<N:3>_RETURN_STOP',
ON -LOW NSO 'AHU_<N:3>_SUPPLY_STOP';
[DUCT-ERU201-202]
ALARM 'LORISE_ERU_<N:201-202>_PAS_LVL*' :
ON -LOW NSO 'ERU_<N:3>_SUPPLY_STOP';
[DUCT-M-305-307]
ALARM 'LORISE_M_<N:305-307>_PAS_LVL*' :
OFF -HIGH NSO 'RETURN_FAN_M<N:3>_STOP',
OFF -HIGH NSO '*LORISE_SMK_PURGE_M<N:>_STOP';
[DUCT-RAF B402,403]
ALARM 'LORISE_RAF_B_<N:402-403>_PAS_LVL*' :
ON -LOW NSO 'RAF_B_<N:3>_STOP';
[DUCT-ERUB 504-506]
ALARM 'LORISE_ERU_B<N:504-506>_PAS_LVL*' :
ON -LOW NSO 'ERUB_<N:3>_RETURN_STOP',
ON -LOW NSO 'ERUB_<N:3>_SUPPLY_STOP',
ON -LOW NSO 'ERUB_<N:3>_DAMPER_RETURN_RMS*';
[DUCT-AHUB 509-510]
ALARM 'LORISE_AHU_B<N:509-510>_PAS_LVL*' :
ON -LOW NSO 'AHUB_<N:3>_RETURN_STOP',
ON -LOW NSO 'AHUB_<N:3>_SUPPLY_STOP';
{************** WATER FRONT DUCT ***********************}
[WATERFRONT-DUCT RETURN ROOF 500-503]
ALARM 'BAY_ROOF_PAS_WF_SMK<N:500-503>_LVL45' :
ON NSO 'ERUB_<N:3>_SUPPLY_START',
ON NSO 'ERUB_<N:3>_DAMPER_RMS_*_MUA';
[WATERFRONT-DUCT SUPPLY ERU B504-B506]
ALARM 'WATERFRT_3RD_SUPPLY_DUCT_ERU_B<N:504-506:3>' : ON NSO 'ERUB_<N:3>_SUPPLY_STOP',
ON NSO 'ERUB_<N:3>_RETURN_STOP',
ON NSO 'ERUB_<N:3>_DAMPER_RMS*';
[WATERFRONT-DUCT SUPPLY ERU B500-B503]
ALARM 'WATERFRT_ROOF_SUPPLY_DUCT_ERU_B<N:500-503:3>' : ON NSO 'ERUB_<N:3>_SUPPLY_STOP',
[WATERFRONT-DUCT SUPPLY AHU B509-B510]
ALARM 'WATERFRT_2ND_SUPPLY_DUCT_AHU_B<N:509-510:3>' : ON NSO 'AHUB_<N:3>_SUPPLY_STOP',
ON NSO 'AHUB_<N:3>_RETURN_STOP';
[WATERFRONT-DUCT SPF STAIRPRESS LO]
ALARM 'WTR_FRT_SPF_DUCT_STAIR_<N:1-2>' : OFF -SET NSO 'BAY_STAIR_PRESS_WTR_FRT_STAIR<N>';
[WATERFRONT-DUCT SPF STAIRPRESS HI]
ALARM 'WTR_FRT_SPF_DUCT_STAIR_<N:1-2>_hirise' : OFF -SET NSO 'BAY_STAIR_PRESS_WTR_FRT_STAIR<N>_HI';
{************** BAY TOWER DUCT ***********************}
[BAY-DUCT MUA B401 ROOF]
ALARM 'BAY_SUPPLY_DUCT_MUA_B_401' : ON NSO 'MUA_B_401_STOP';
[BAY-DUCT MUA B402 ROOF]
ALARM 'BAY_SUPPLY_DUCT_MUA_B_402' : ON NSO 'AHU_B402_MUA_STOP';
[BAY-DUCT 1ST AHU 402 SUPPLY]
ALARM 'BAY_SUPPLY_DUCT_AHU_B_402' : ON NSO 'AHU_B_402_STOP',
ON NSO 'RAF_B_402_STOP';
[BAY-DUCT 1ST ERU 201 SUPPLY]
ALARM 'BAY_SUPPLY_DUCT_ERU_<N:201-202:3>' : ON NSO 'ERU_<N>_SUPPLY_STOP';
[BAY-DUCT 1ST SAF B402 SUPPLY]
ALARM 'BAY_SUPPLY_DUCT_SAF_B_402' : ON NSO 'SAF_B_402_STOP';
[BAY-DUCT SUPPLY F_B409,410]
ALARM 'BAY_SUPPLY_DUCT_FC_B_<N:409-410:3>' : ON NSO 'AHU_FC_B_<N:3>_STOP',
ON NSO 'AHU_<N:3>_SUPPLY_STOP';
[BAY-DUCT SUPPLY 3RD FC B403]
ALARM 'BAY_SUPPLY_DUCT_AHU_B_403*' :
ON NSO 'AHU_B_403_STOP',
ON NSO 'RAF_B_403_STOP';
[BAY-DUCT SUPPLY 3RD RM SVC KITCHEN]
ALARM 'BAY_SUPPLY_DUCT_AHU_RMSVC1' : ON NSO 'BAY_RMSVC1_AHU_SUPPLY_STOP';
[BAY-DUCT SUPPLY AC 413,414]
ALARM 'BAY_SUPPLY_DUCT_AHU_AC_B<N:413-414:3>' : ON NSO 'AHU_AC_B<N:3>_SUPPLY_STOP';
{************** GRAND LOBBY/MARINA DUCT ********************}
[GRANDLOBBY-DUCT SUPPLY 1ST M 307]
ALARM SMOKE 'GL_SUPPLY_DUCT_M_307' : ON NSO '*LORISE_SMK_PURGE_M307_STOP',
ON NSO 'SUPPLY_FAN_M307_STOP';
[GRANDLOBBY-DUCT SUPPLY 1ST M 306]
ALARM SMOKE 'GL_SUPPLY_DUCT_M_306' : ON NSO 'RETURN_FAN_M306_STOP',
ON NSO 'SUPPLY_FAN_M306_STOP';
[GRANDLOBBY-DUCT SUPPLY 1ST M 305]
ALARM SMOKE 'GL_SUPPLY_DUCT_M_305' : ON NSO 'SUPPLY_FAN_M305_STOP',
ON NSO 'RETURN_FAN_M305_STOP';
[GRANDLOBBY-DUCT SUPPLY 1ST M 301]
ALARM SMOKE 'GL_SUPPLY_DUCT_M_301' : ON NSO 'SUPPLY_FAN_M301_STOP';
{************** BUFFET/POOL PANTRY - DUCTS **************************}
[POOL-DUCT SUPPLY PANTRY MUA B501]
ALARM SMOKE 'POOL_PANTRY_SUPPLY_DUCT_MUA_B_501' : ON NSO '*LORISE_SMK_PURGE_MUA_B501_STOP';
[BUFFET-DUCT SUPPLY 500-508]
ALARM 'BUFFET_SUPPLY_DUCT_AHU<N:500-507,508:3>' : ON NSO 'AHU_<N:3>_RETURN_STOP',
[BUFFET-DUCT SUPPLY 401,404,405]
ALARM 'BUFFET_SUPPLY_DUCT_AHU<N:401,404-405:3>' : ON NSO 'AHU_<N:3>_RETURN_STOP',
{************** E L E V A T O R ******************************}
{******************* rules 107 ************************************}
{************** ELEVATOR SHUNT ***********************}
[HARBOR SERVICE SHUNT ELEVATOR]
ALARM 'HARBOR_HEAT_ELEV_SERVICE_SHAFT_22.3.428' :
ON NSO '*HARBOR_ELEV_*_LVL_MAIN*',
DELAY 30,
ON NSO 'HARBOR_ELEV_SERVICE_SHUNT_22.3.448';
[HARBOR PUBLIC SHUNT ELEVATOR]
ALARM 'HARBOR_HEAT_ELEV_PUBLIC_SHAFT_22.2.131' :
DELAY 30,
ON NSO 'HARBOR_ELEV_PUBLIC_SHUNT_22.2.140';
[ATRIUM SHUNT ELEVATOR]
ALARM 'Atrium_HEAT_SHUNT*' :
ON NSO '*ATRIUM_ELEV_*_LVL_MAIN*',
DELAY 30,
ON NSO 'Atrium_ELEV_SHUNT*';
{************** WATER FRONT PreAction/ELEVATOR ***********************}
[WATERFRT 27th PreACTION PANEL]
ALARM 'BAY_27TH_PAS_preaction1_LVL26' :
ON NSO 'WTR_FRT_PUBLIC_ELEV_HATFLASH_LOW1',
ON NSO 'WTR_FRT_SVC_ELEV_HATFLASH_LOW1',
ON NSO 'WTR_FRT_SVC_ELV_DAMPER_LOW1',
ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_LOW1',
ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_LOW2';
[WATERFRT ROOF PreACTION PANEL]
ALARM 'BAY_ROOF_PAS_preaction1_LVL45' :
ON NSO 'WTR_FRT_PUBLIC_ELEV_HATFLASH_HIGH1',
ON NSO 'WTR_FRT_SVC_ELEV_HATFLASH_HIGH1',
ON NSO 'WTR_FRT_SVC_ELV_DAMPER_HIGH1',
ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_HIGH_50_51',
ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_HIGH_52_53';
[WATERFRT SVC ELV TOP SHAFT SMK-LOW]
ALARM SMOKE 'WF_SVC_ELEV_TOP_SHAFT_SMK_LOW1' : ON NSO 'WTR_FRT_SVC_ELV_DAMPER_LOW1',
ON NSO 'WTR_FRT_SVC_ELEV_RECALL_MAIN_LOW1',
ON NSO 'WTR_FRT_SVC_ELEV_HATFLASH_LOW1';
[WATERFRT SVC ELV TOP SHAFT SMK-HI]
ALARM SMOKE 'WF_SVC_ELEV_TOP_SHAFT_SMK_HI1' : ON NSO 'WTR_FRT_SVC_ELV_DAMPER_HIGH1',
ON NSO 'WTR_FRT_SVC_ELEV_RECALL_MAIN_HIGH1',
ON NSO 'WTR_FRT_SVC_ELEV_HATFLASH_HIGH1';
[WTRFRT PASS TOP SHAFT SMK-LOW-SINGLE]
ALARM SMOKE 'WF_PASS_ELEV_TOP_SHAFT_SMK_LOW1' : ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_LOW1',
ON NSO 'WTR_FRT_PUBLIC_ELEV_RECALL_MAIN_LOW1',
ON NSO 'WTR_FRT_PUBLIC_ELEV_HATFLASH_LOW1';
[WTRFRT PASS TOP SHAFT SMK-LOW-DOUBLE]
ALARM SMOKE 'WF_PASS_ELEV_TOP_SHAFT_SMK_LOW2' : ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_LOW2',
[WATERFRT PASS ELV TOP SHAFT CARS 50-51]
ALARM SMOKE 'WF_PASS_ELEV_TOP_SHAFT_SMK_HI_50_51' : ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_HIGH_50_51',
ON NSO 'WTR_FRT_PUBLIC_ELEV_RECALL_MAIN_HIGH1',
ON NSO 'WTR_FRT_PUBLIC_ELEV_HATFLASH_HIGH1';
[WATERFRT PASS ELV TOP SHAFT CARS 52-53]
ALARM SMOKE 'WF_PASS_ELEV_TOP_SHAFT_SMK_HI_52_53' : ON NSO 'WTR_FRT_PUBLIC_ELV_DAMPER_HIGH_52_53',
[WATERFRT PREACTION P2 ELEV-LO]
ALARM 'WF_PREACTION_SHUNT_LOW1' :
ON NSO 'WATERFRONT_SVC_ELEV_SHUNT',
ON NSO 'WATERFRONT_PASS_ELEV_SHUNT';
[WATERFRT PREACTION P2 ELEV-HI]
ALARM 'WF_PREACTION_SHUNT_HIGH1' :
ON NSO 'WATERFRONT_SVC_ELEV_SHUNT_HIGH',
ON NSO 'WATERFRONT_PASS_ELEV_SHUNT_HIGH';
{************** BUFFET ELEVATOR ******************************}
[BUFFET ELEV MECH RM SMOKE]
ALARM 'BUFFET_SVC_ELEV_MECH_RM_SMK1' : ON NSO 'BUFFET_ELEV_RECALL_MAIN*';
[BUFFET SVC ELEV MECH RM HEAT]
ALARM 'BUFFET_SVC_ELEV_HEAT_MECH_RM1' : ON NSO 'BUFFET_ELEV_SHUNT',
ON NSO 'BUFFET_SHUNT_STATUS_ELEV*';
[BUFFET ELEV TOP SHAFT SMOKE]
ALARM 'BUFFET_ELEV_TOP_SHAFT_SMOKE1' : ON NSO 'BUFFET_ELEV_RECALL_MAIN*';
[BUFFET ELEV PIT SMOKE]
ALARM 'BUFFET_ELEV_PIT_SMK1' : ON NSO 'BUFFET_ELEV_RECALL_ALT*';
[BUFFET ELEV BOTTOM SHAFT HEAT]
ALARM 'BUFFET_ELEV_BOTTOM_SHAFT_HEAT*' :
{************** POOL/SPA ELEVATOR ******************************}
[POOL ELV TOP OF SHAFT SMOKE]
ALARM 'POOL_ELEV_TOP_SHAFT_SMOKE1' :
ON NSO 'POOL_ELV_PRIMARY_HATFLASH_1',
ON NSO 'POOL_ELEV_RECALL_MAIN';
[POOL MACH RM AND PIT SMKS]
ALARM 'POOL_ELEV_MACH_RM_SMK*' :
ON NSO 'POOL_ELV_ALT_HATFLASH_1',
ON NSO 'POOL_ELEV_RECALL_ALT';
[POOL ELV AND MACH RM HEATS]
ALARM 'POOL_ELEV_MACH_RM_HEAT*' :
ON NSO 'POOL_SHUNT_STATUS*',
ON NSO 'POOL_ELEV_SHUNT';
{************** VALET GARAGE *******************}
[VALET GARAGE ELEV MACH RM]
ALARM SMOKE 'VALET_SMK_GARAGE_1' : ON AUDIBLE 'VALET_HORNSTROBE1',
ON NSO 'VALET_ALT_RECALL',
ON NSO 'VALET_SIGNAL_TO_SIEMENS';
[VALET GARAGE TOP SHAFT SMOKE]
ALARM SMOKE 'VALET_MAIN_RECALL_SMK*' : ON AUDIBLE 'VALET_HORNSTROBE1',
ON NSO 'VALET_MAIN_RECALL',
[VALET GARAGE METHANE ALARM]
ALARM HEAT 'GENERAL_METHANE_HIGH_LEVEL' : ON AUDIBLE 'VALET_HORNSTROBE1';
{*************************RULES 131 ***************************************}
{************** AND STATEMENTS ******************************}
[AND-ATRIUM 3RD MECH PRE ACTION]
ALARM AND 'AND_Atrium_PREACTION' : ON -LOW NSO 'PREACT_SOLENOID__@16.2.188'; {SMOKE3rd fl preaction Switch Gear rm}
[AND-1ST LORISE P1]
ALARM AND 'AND_LORISE_1ST_FLR':
AMPON -HIGH 'ZA20_AMP' TO 'Ch_Evac_01_08',
DELAY 0,
MSGON 'Default_Evac_01_08' TO 'Ch_Evac_01_08',
ACTIVATE 'Lorise_Total_Evac_HIGH',
ACTIVATE 'Lorise_Recall_to_Alt';
[AND-2ND LORISE P1]
ALARM AND 'AND_LORISE_2ND_FLR' :
DELAY 0,
ACTIVATE 'Lorise_Recall_to_MAIN_HIGH';
[AND-3RD LORISE P1]
ALARM AND 'AND_LORISE_3RD_FLR' :
DELAY 0,
[AND-BAY 4TH-46TH P-1s]
ALARM AND 'AND_BAY_TWR_*_FLR_LVL<N:4-45>' : AMPON -HIGH 'ZA20_AMP' TO 'Ch_Evac_01_08',
DELAY 0,
ON -HIGH SUP 'BAY_*_LVL<N>_SPEAKER*',
ON -HIGH SUP 'BAY_*_LVL<N+1>_SPEAKER*',
ON -HIGH SUP 'BAY_*_LVL<N-1>_SPEAKER*',
ON -HIGH VISIBLE 'BAY_*_LVL<N>_STROBE*',
ON -HIGH VISIBLE 'BAY_*_LVL<N+1>_STROBE*',
ON -HIGH VISIBLE 'BAY_*_LVL<N-1>_STROBE*',
ON -HIGH VISIBLE 'BAY_GUESTRM_*_STROBE_HANDI_LVL<N>',
ON -HIGH VISIBLE 'BAY_GUESTRM_*_STROBE_HANDI_LVL<N+1>',
ON -HIGH VISIBLE 'BAY_GUESTRM_*_STROBE_HANDI_LVL<N-1>',
ON -HIGH NSO 'WTR_FRONT_RM_*_GEN_BEDSHAKE_LVL<N>',
ON -HIGH NSO 'WTR_FRONT_RM_*_GEN_BEDSHAKE_LVL<N+1>',
ON -HIGH NSO 'WTR_FRONT_RM_*_GEN_BEDSHAKE_LVL<N-1>',
ON -HIGH NSO 'WTR_FRONT_*_Fl_DAMPER_LVL<N>',
ON -HIGH NSO 'WTR_FRONT_*_Fl_DAMPER_LVL<N+1>',
ON -HIGH NSO 'WTR_FRONT_*_Fl_DAMPER_LVL<N-1>',
ON -HIGH NSO 'BAY_WTR_FRT_LVL<N>_DOORS*',
ON -HIGH NSO 'BAY_WTR_FRT_LVL<N+1>_DOORS*',
ON -HIGH NSO 'BAY_WTR_FRT_LVL<N-1>_DOORS*',
ACTIVATE 'BAY_TWR_HI_RISE',
ACTIVATE 'WATERFRT_TWR_HI_RISE',
ON -HIGH NSO '*Harrahs*_PAS_LVL_ALL*';
[AND-HARBOR TWR 4TH-16TH P-1s]
ALARM AND 'AND_HARBOR_TWR_*_FLR_LVL<N:4-16>' : AMPON -HIGH 'ZA20_AMP' TO 'Ch_Evac_01_08',
DELAY 0,
ON -HIGH '*Harbor*_PAS_LVL_ALL*',
ON -HIGH NSO '*Harbor*_PAS_LVL_<N>_*',
ON -HIGH NSO '*Harbor*_PAS_LVL_<N+1>_*',
ON -HIGH NSO '*Harbor*_PAS_LVL_<N-1>_*',
ON -HIGH SUP '*Harbor*_PAS_LVL_<N>_*',
ON -HIGH SUP '*Harbor*_PAS_LVL_<N+1>_*',
ON -HIGH SUP '*Harbor*_PAS_LVL_<N-1>_*',
ON -HIGH VISIBLE '*Harbor*_PAS_LVL_<N>_*',
ON -HIGH VISIBLE '*Harbor*_PAS_LVL_<N+1>_*',
ON -HIGH VISIBLE '*Harbor*_PAS_LVL_<N-1>_*';
[AND-MARINA TWR 3A-16TH P-1s]
ALARM AND 'AND_MARINA_TWR_*_FLR_LVL<N:4-17>' : AMPON -HIGH 'ZA20_AMP' TO 'Ch_Evac_01_08',
DELAY 0,
ON -HIGH NSO '*Harrahs_DIALER_PAS_LVL_*',
ON -HIGH '*MARINA*_PAS_LVL_ALL*',
ON -HIGH NSO '*MARINA*_PAS_LVL_<N>_*',
ON -HIGH NSO '*MARINA*_PAS_LVL_<N+1>_*',
ON -HIGH NSO '*MARINA*_PAS_LVL_<N-1>_*',
ON -HIGH SUP '*MARINA*_PAS_LVL_<N>_*',
ON -HIGH SUP '*MARINA*_PAS_LVL_<N+1>_*',
ON -HIGH SUP '*MARINA*_PAS_LVL_<N-1>_*',
ON -HIGH VISIBLE '*MARINA*_PAS_LVL_<N>_*',
ON -HIGH VISIBLE '*MARINA*_PAS_LVL_<N+1>_*',
ON -HIGH VISIBLE '*MARINA*_PAS_LVL_<N-1>_*';
[AND-ATRIUM TWR 2ND-16TH P-1s]
ALARM AND 'AND_ATRIUM_TWR_HIGH_RISE' : AMPON -HIGH 'ZA20_AMP' TO 'Ch_Evac_01_08',
DELAY 0,
AMPON -LOW 'ZA20_AMP' TO 'Ch_Evac_01_08',
ON -HIGH NSO '*Harrahs_DIALER_PAS_LVL_ALL*',
ON -HIGH NSO '*Atrium*_PAS_LVL_*',
ON -HIGH SUP '*Atrium*_PAS_LVL_*',
ON -HIGH VISIBLE '*Atrium*_PAS_LVL_*';
[AND-THEATRE 1ST FLR LORISE P1]
ALARM AND 'AND_THEATRE_1ST_FLR':
ON -LOW NSO 'Harrahs_DIALER_PAS_LVL_ALL*',
ON -LOW NSO '*THEATER*_PAS_LVL_ALL*',
ON -LOW SUP '*THEATER*_PAS_LVL_ALL*',
ON -LOW VISIBLE '*THEATER*_PAS_LVL_ALL*',
ON NSO '*THEATER*ELEV_PAS_LVL_ALT*';
[AND-THEATRE_2ND_3RD_FLR]
ALARM 'AND_THEATRE_2ND_3RD_FLR' :
ON -LOW NSO '*Harrahs_DIALER_PAS_LVL_ALL*',
ON NSO '*THEATER*ELEV_PAS_LVL_MAIN*';
{************** BAY TOWER HANDICAP GUEST RM SMKS/CO ***********************}
[BAY-6TH HANDI GUEST SMK/CO DET] ALARM 'BAY_GUESTRM_6052_*' : ON VIS 'BAY_GUESTRM_6052_STROBE_HANDI_LVL6';
[BAY-7TH HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_7051_*' : ON VIS 'BAY_GUESTRM_7051_STROBE_HANDI_LVL7';
[BAY-7TH HANDI GUEST SMK/CO DET-2] ALARM 'BAY_GUESTRM_7052_*' : ON VIS 'BAY_GUESTRM_7052_STROBE_HANDI_LVL7';
[BAY-10TH HANDI GUEST SMK/CO DET] ALARM 'BAY_GUESTRM_10051_*' : ON VIS 'BAY_GUESTRM_10051_STROBE_HANDI_LVL10';
[BAY-11TH HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_11051_*' : ON VIS 'BAY_GUESTRM_11051_STROBE_HANDI_LVL11';
[BAY-11TH HANDI GUEST SMK/CO DET-2] ALARM 'BAY_GUESTRM_11052_*' : ON VIS 'BAY_GUESTRM_11052_STROBE_HANDI_LVL11';
[BAY-14TH HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_14051_*' : ON VIS 'BAY_GUESTRM_14051_STROBE_HANDI_LVL13';
[BAY-14TH HANDI GUEST SMK/CO DET-2] ALARM 'BAY_GUESTRM_14052_*' : ON VIS 'BAY_GUESTRM_14052_STROBE_HANDI_LVL13';
[BAY-15TH HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_15051_*' : ON VIS 'BAY_GUESTRM_15051_STROBE_HANDI_LVL14';
[BAY-15TH HANDI GUEST SMK/CO DET-2] ALARM 'BAY_GUESTRM_15052_*' : ON VIS 'BAY_GUESTRM_15052_STROBE_HANDI_LVL14';
[BAY-15TH HANDI GUEST SMK/CO DET-3] ALARM 'BAY_GUESTRM_15060_*' : ON VIS 'BAY_GUESTRM_15060_STROBE_HANDI_LVL14';
[BAY-15TH HANDI GUEST SMK/CO DET-4] ALARM 'BAY_GUESTRM_15065_*' : ON VIS 'BAY_GUESTRM_15065_STROBE_HANDI_LVL14';
[BAY-15TH HANDI GUEST SMK/CO DET-5] ALARM 'BAY_GUESTRM_15066_*' : ON VIS 'BAY_GUESTRM_15066_STROBE_HANDI_LVL14';
[BAY-15TH HANDI GUEST SMK/CO DET-6] ALARM 'BAY_GUESTRM_15059_*' : ON VIS 'BAY_GUESTRM_15059_STROBE_HANDI_LVL14';
[BAY-17TH HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_17051_*' : ON VIS 'BAY_GUESTRM_17051_STROBE_HANDI_LVL16';
[BAY-17TH HANDI GUEST SMK/CO DET-2] ALARM 'BAY_GUESTRM_17052_*' : ON VIS 'BAY_GUESTRM_17052_STROBE_HANDI_LVL16';
[BAY-18TH HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_18051_*' : ON VIS 'BAY_GUESTRM_18051_STROBE_HANDI_LVL17';
[BAY-18TH HANDI GUEST SMK/CO DET-2] ALARM 'BAY_GUESTRM_18052_*' : ON VIS 'BAY_GUESTRM_18052_STROBE_HANDI_LVL17';
[BAY-18TH HANDI GUEST SMK/CO DET-3] ALARM 'BAY_GUESTRM_18059_*' : ON VIS 'BAY_GUESTRM_18059_STROBE_HANDI_LVL17';
[BAY-18TH HANDI GUEST SMK/CO DET-4] ALARM 'BAY_GUESTRM_18060_*' : ON VIS 'BAY_GUESTRM_18060_STROBE_HANDI_LVL17';
[BAY-18TH HANDI GUEST SMK/CO DET-5] ALARM 'BAY_GUESTRM_18066_*' : ON VIS 'BAY_GUESTRM_18066_STROBE_HANDI_LVL17';
[BAY-23RD HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_23071_*' : ON VIS 'BAY_GUESTRM_23071_STROBE_HANDI_LVL22';
[BAY-25TH HANDI GUEST SMK/CO DET-1] ALARM 'BAY_GUESTRM_25069_*' : ON VIS 'BAY_GUESTRM_3000_STROBE_HANDI_LVL24';
[BAY-25TH FLR CO DET-1] ALARM 'BAY_GUESTRM_25*_CO' : ON NSO 'BAY_25TH_FLR_GAS_SHUTOFF';
{************** WATERFRONT ******************************}
{************** WTR FRONT TOWER GUEST RM SMKS ***********************}
[WF-4TH FL GUEST SMKS] ALARM SMOKE 'WF_BAY_GUESTRM_<N:4077-4095,4097-4099>_SMOKE' :
ON NSO 'WTR_FRONT_RM_<N:4>_DAMPER';
[WF-4TH FL HANDI GUEST SMKS] ALARM SMOKE 'WF_BAY_GUESTRM_<N:4077,4082,4090,4093>_SMOKE' :
ON VISIBLE 'BAY_4TH_LVL4_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:4>_STROBE_HANDI_LVL4',
ON NSO 'WTR_FRONT_RM_<N:4>_LOCAL_BEDSHAKE';
[WF-4th FL GUEST END SUITES] ALARM SMOKE 'WF_BAY_GUESTRM_<N:410-411>_SMOKE*' :
ON SMOKE 'WF_BAY_GUESTRM_<N:3>_SMOKE*',
ON VISIBLE 'BAY_GUESTRM_<N:3>_STROBE_HANDI_LVL4',
ON NSO 'WTR_FRONT_RM_<N:3>_LOCAL_BEDSHAKE',
ON NSO 'WTR_FRONT_RM_<N:3>_DAMPER',
ON NSO 'WTR_FRONT_RM_<N+1>_DAMPER';
[WF-5TH FL GUEST SMKS] ALARM SMOKE 'WF_BAY_GUESTRM_<N:5077-5095,5097-5099>_SMOKE' :
[WATERFRT 5TH FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:5077,5082,5090,5093,5099>_SMOKE' :
ON VISIBLE 'BAY_5TH_LVL5_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:4>_STROBE_HANDI_LVL5',
[WATERFRT 5th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:5100-5101>_SMOKE*' :
ON SMOKE 'WF_BAY_GUESTRM_<N:4>_SMOKE*',
ON NSO 'WTR_FRONT_RM_<N:4>_DAMPER',
[WATERFRT 6TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:6077-6095,6097-6099>_SMOKE' :
[WATERFRT 6TH FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:6077,6082>_SMOKE' :
ON VISIBLE 'BAY_6TH_LVL6_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:4>_STROBE_HANDI_LVL6',
[WATERFRT 6th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:6100-6101>_SMOKE*' :
[WATERFRT 7TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:7077-7095,7097-7099>_SMOKE' :
[WATERFRT 7th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:7100-7101>_SMOKE*' :
ON VISIBLE 'BAY_7TH_LVL7_STROBE_WF_SYNC1',
[WATERFRT 8TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:8077-8095,8097-8099>_SMOKE' :
[WATERFRT 8th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:8100-8101>_SMOKE*' :
[WATERFRT 9TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:9077-9095,9097-9099>_SMOKE' :
[WATERFRT 9th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:9100-9101>_SMOKE*' :
[WATERFRT 10TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:10077-10095,10097-10099>_SMOKE' :
ON NSO 'WTR_FRONT_RM_<N:5>_DAMPER';
[WATERFRT 10th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:10100-10101>_SMOKE*' :
ON SMOKE 'WF_BAY_GUESTRM_<N:5>_SMOKE*',
ON NSO 'WTR_FRONT_RM_<N:5>_DAMPER',
[WATERFRT 11TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:11077-11095,11097-11099>_SMOKE' :
[WATERFRT 11th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:11100-11101>_SMOKE*' :
[WATERFRT 12TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:12077-12095,12097-12099>_SMOKE' :
[WATERFRT 12th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:12100-12101>_SMOKE*' :
[WATERFRT 14TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:14077-14095,14097-14099>_SMOKE' :
[WATERFRT 14th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:14100-14101>_SMOKE*' :
[WATERFRT 15TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:15077-15095,15097-15099>_SMOKE' :
[WATERFRT 15th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:15100-15101>_SMOKE*' :
[WATERFRT 16TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:16077-16095,16097-16099>_SMOKE' :
[WATERFRT 16th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:16100-16101>_SMOKE*' :
[WATERFRT 17TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:17077-17095,17097-17099>_SMOKE' :
[WATERFRT 17th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:17100-17101>_SMOKE*' :
[WATERFRT 18TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:18077-18095,18097-18099>_SMOKE' :
[WATERFRT 18th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:18100-18101>_SMOKE*' :
[WATERFRT 19TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:19077-19095,19097-19099>_SMOKE' :
[WATERFRT 19TH FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:19077,19079,19080,19084>_SMOKE' :
ON VISIBLE 'BAY_19TH_LVL18_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL18',
ON NSO 'WTR_FRONT_RM_<N:5>_LOCAL_BEDSHAKE';
[WATERFRT 19th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:19100-19101>_SMOKE*' :
[WATERFRT 20TH FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:20077-20095,20097-20099>_SMOKE' :
[WATERFRT 20TH FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:20077,20079,20080,20084>_SMOKE' :
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL19',
[WATERFRT 20th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:20100-20101>_SMOKE*' :
[WATERFRT 21st FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:21077-21095,21097-21099>_SMOKE' :
[WATERFRT 21st FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:21100-21101>_SMOKE*' :
[WATERFRT 22nd FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:22077-22095,22097-22099>_SMOKE' :
[WATERFRT 22nd FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:22100-22101>_SMOKE*' :
[WATERFRT 23rd FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:23077-23095,23097-23099>_SMOKE' :
[WATERFRT 23rd FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:23100-23101>_SMOKE*' :
[WATERFRT 24th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:24077-24095,24097-24099>_SMOKE' :
[WATERFRT 24th FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:24077,24080,24090,24093>_SMOKE' :
ON VISIBLE 'BAY_24th_LVL23_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL23',
[WATERFRT 24th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:24100-24101>_SMOKE*' :
[WATERFRT 25th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:25077-25095,25097-25099>_SMOKE' :
[WATERFRT 25th FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:25077,25080>_SMOKE' :
ON VISIBLE 'BAY_25th_LVL24_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL24',
[WATERFRT 25th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:25100-25101>_SMOKE*' :
[WATERFRT 26th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:26077-26095,26097-26099>_SMOKE' :
[WATERFRT 26th FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:26086-26087>_SMOKE' :
ON VISIBLE 'BAY_26th_LVL25_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL25',
[WATERFRT 26th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:26100-26101>_SMOKE*' :
[WATERFRT 27th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:27077-27095,27097-27099>_SMOKE' :
[WATERFRT 27th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:27100-27101>_SMOKE*' :
[WATERFRT 28th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:28077-28095,28097-28099>_SMOKE' :
[WATERFRT 28th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:28100-28101>_SMOKE*' :
[WATERFRT 29th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:29075-29095,29097-29099>_SMOKE' :
[WATERFRT 29th FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:29090,29093>_SMOKE' :
ON VISIBLE 'BAY_29th_LVL28_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL28',
[WATERFRT 29th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:29100-29101>_SMOKE*' :
[WATERFRT 30th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:30075-30095,30097-30099>_SMOKE' :
[WATERFRT 30th FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:30086,30091,30098>_SMOKE' :
ON VISIBLE 'BAY_30th_LVL29_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL29',
[WATERFRT 30th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:30100-30101>_SMOKE*' :
[WATERFRT 31st FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:31075-31095,31097-31099>_SMOKE' :
[WATERFRT 31st FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:31086,31091>_SMOKE' :
ON VISIBLE 'BAY_31st_LVL30_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL30',
[WATERFRT 31st FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:31100-31101>_SMOKE*' :
[WATERFRT 32nd FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:32075-32095,32097-32099>_SMOKE' :
[WATERFRT 32nd FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:32086,32091>_SMOKE' :
ON VISIBLE 'BAY_32nd_LVL31_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:5>_STROBE_HANDI_LVL31',
[WATERFRT 32nd FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:32100-32101>_SMOKE*' :
[WATERFRT 33rd FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:3375-3395,3397-3399>_SMOKE' :
[WATERFRT 33rd FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:3300-3301>_SMOKE*' :
[WATERFRT 34th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:3475-3495,3497-3499>_SMOKE' :
[WATERFRT 34th FLR HANDI GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:3475,3486>_SMOKE' :
ON VISIBLE 'BAY_34th_LVL33_STROBE_WF_SYNC1',
ON VISIBLE 'BAY_GUESTRM_<N:4>_STROBE_HANDI_LVL33',
[WATERFRT 34th FLR GUESTRM END SUITES]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:3400-3401>_SMOKE*' :
[WATERFRT 35th FLR GUESTRM SMKS]
ALARM SMOKE 'WF_BAY_GUESTRM_<N:3575-3595,3597-3599>_SMOKE' :
[WATERFRT 35th FLR GUESTRM END S
************* needed to cut the bottom off board would not allow the sizes *****************
view attached file for whole file
PROJRULE.TXT
(104.73 KiB) Downloaded 1546 times
Nirujan
Re: 2 year project - Rules - PAS
Post by Nirujan »
Oh god this much rules!!!, can i know the system detectors /modules quantity's..
no sure I think around 5,000 devices
the hard part was it has 5 towers with floor above and below voice Evac with PAS
karthiktamil
Post by karthiktamil »
Leo wrote:{********************************************
2. O N E T O O N E
3. D U C T
4. E L E V A T O R
5. P A S
6. AND STATEMENTS
9. L E D
10. S W I T C H E S
11. AMPS transfer
STUP: DELAY 5,
[ALARM SILENCE]
ALARMSILENCE:
DELAY 0,
[RESET STAGE ONE]
R1: DELAY 0,
DELAY 0,
DELAY 0,
DELAY 1,
DELAY 0,
DELAY 2,
DELAY 0,
DELAY 0,
DELAY 0,
DELAY 2,
DELAY 0,
DELAY 0,
OFF -SET SUP '*',
OFF -SET NSO '*';
[COMMAND-PAS OFF]
[DUCT-AHU401-508]
[DUCT-ERU201-202]
[DUCT-M-305-307]
[DUCT-RAF B402,403]
[DUCT-ERUB 504-506]
[DUCT-AHUB 509-510]
DELAY 30,
DELAY 30,
DELAY 30,
[AND-1ST LORISE P1]
DELAY 0,
[AND-2ND LORISE P1]
DELAY 0,
[AND-3RD LORISE P1]
DELAY 0,
DELAY 0,
DELAY 0,
DELAY 0,
DELAY 0,
is is possible to send the SDU database for reference
karthigym36@gmail.com
fasiwi
Post by fasiwi »
Wow. Need to study this. Thanks!
fasiwi
ericflorendo
Post by ericflorendo »
Good day guys..can I have a copy of SDU database too?
junjan100489@gmail.com
TIA..
