A fire alarm system has a number of devices working together to detect and warn people through visual and audio appliances when smoke, fire, carbon monoxide or other emergencies are present.
A handheld programmer is the easy tool to configure the system. It encodes every detectors smoke, heat, gas, manual call point, input output modules etc.
Fire alarm system instruction manual should be carefully read before operation. All steps should be followed.
If you do not know how to set up the fire security system, here is a guidance of how to set up fire alarm system
You can know how to configure and debug the fire alarm system.
Check attachment of addressable fire alarm devices manual.
Manual for addressable fire devices
- Contact:
- Manual for addressable fire devices.pdf
- (372.78 KiB) Downloaded 901 times
