i need to buy the dongle for EST3
josephdma
Re: i need to buy the dongle for EST3
Post by josephdma »
i can trade for xls 1000 dng image
duro
Post by duro »
The download files are not found.
could you email them to me - duro@simplex.kz
Hiep Nguyen
Post by Hiep Nguyen »
Dears all,
I need to buy the dongle key for EST3, because i didn't works in the old company is distributor in Vietnames.
Can you help me buy the dongle key for EST3 cabinet?
Thanks & Best Regards
Hiep
cmadradi
Post by cmadradi »
Hello everybody!
I'm in need for some dmp file of a software key, however it must be done on a 64 bits system (It must include the serial of the integrator, it will only be used in the developing). I can trade for any of the following:
Verifire Tools 9.0 working without an HID
Unlocked Multikey 32 bits for 2-SDU and 3-SDU system for XLS-1000, Simplex, EST2. EST3, Fireworks
Same Unlocked Multikey 64 bits (after developing from the supplied dmp)
Cheers mates!
ESTrr
Post by ESTrr »
I have an EST3 dongle for sale
Hiep Nguyen
lts-maroc wrote:These File i will join to you contains the file cracked, but need hat you follow these instructions, it works as EST3 Software Key:
1- i tested with XP system
2- Return the date of the system to a Valid from 26/Aug/2010 to 2/Sep/2010, you choose one date .
3- Open the "USB Dongle Backup and Recovery 2012", go the the tab "Driver", then "Install Driver", verify in this tab, in "Driver Statuts "that the driver is installed.
4- Go to the "Emulator" Tab then "Start Service", wait untill it started.
5- Load dump, witch is "1A4B27EB.dng".
6-run your application.
7-Enjoy.
If you want to install a new application of 3-SDU, you have just to repeat from 1---5 , then nstall the application, the PIN code is "EDF5856EEF3CEB93" , please the date is so important to change it before start the operation.
Please go to these URL to download the files: https://rapidshare.com/files/3728587953/1A4B27EB.dng
https://rapidshare.com/files/381519616/ ... up2012.zip
Enjoy.
Could you email them to me - ngochiep.me@gmail.com
venkat2891
Post by venkat2891 »
please send me the link to download the same.
venkat2891
my email address coopervenky@gmail.com
facess1
Post by facess1 »
lts-maroc wrote:Dear Friends,
I have a solution for you, to avoid any lose of your HASP key, you can dump the key with dongle services, or get a cracked software that can dump it and emulate it when you don't need to use the dongle key.
I leave the company that i worked for, and i use it for my own projects, for maintenances.
Good Luck.
Yassine
how much to copy dongle key
isatronix
Post by isatronix »
nothing
