I have CAMWorks and a RJ11 to DB9 cable. Plugging into the onboard RJ11 socket of the FCI-7100 will not allow me to connect.
The manual says I do not need the INI-7100 on a standalone 7100. Any suggestions?
Thank you in advance
Gamewell CAMWorks and FCI-7100
Re: Gamewell CAMWorks and FCI-7100
hirondparker wrote: ↑Sun Feb 28, 2021 6:24 pm I have CAMWorks and a RJ11 to DB9 cable. Plugging into the onboard RJ11 socket of the FCI-7100 will not allow me to connect.
can try first with HyperTerminal just to make sure everything is fine these are the parameters:
Bits per second: 9600
Data bits: 8
Parity: None
Stop bits: 1
Flow Control: None
some old firmware versions of 7100 will not connect to the latest version of CAMWorks,
Regards.
Thank you. I tried that. I may have to go over the pin outs of the cable I am using. It may be the culprit.
I appreciate your input.
Found the cable information with pin outs (attached). All is well
- E3 SERIES GAMEWELL-CABLE PROGRAMMER.pdf
- (55.45 KiB) Downloaded 885 times
Using Camworks I can connect but the "upload' option is not highlighted only download. Any idea why I cannot upload the existing configuration?
Hi, for the 7100 panels the upload option is on the download page "7100 upload",rondparker wrote: ↑Tue May 11, 2021 11:25 am Using Camworks I can connect but the "upload' option is not highlighted only download. Any idea why I cannot upload the existing configuration?
just click download to see what I'm talking about...
Regards.
CamWorks for E3 S3 7100 FCI Gamewell HoneyWell Panels latest Ver 3.60.003 -DEC 2020
permanent license all options enabled
write me for more info:
technicalsupp-999@hotmail.com
regards
regards
