EST3 to BMS Communications Bridge FSB-PC
hijazih
Post by hijazih »
Hi all,
Has anyone used FSB-PC before?? please advise how to import the addresses to the FSP-PC configuration software.
junjun
Re: EST3 to BMS Communications Bridge FSB-PC
Post by junjun »
give me the details or the points to be monitored by BMS i will configure it for you..
hijazih
Post by hijazih »
I still didnt run the fire alarm panel. I'm still in the installation phase. If u can tell me how to deal with such device it would be good.
what details you want, i can get some data from an existing project so that to get familiar with this device.
thank you
junjun
Post by junjun »
You can give me which device logical address of fire alarm to be monitored and what kind of communication to be use between fsb-pc and bms.
junjun
Post by junjun »
Its either one of this protocols:
Bacnet-ethernet
Bacnet-ip
Modbus
Lonworx
Etc...
hijazih
Post by hijazih »
Can i use 2 protocols simultaneously, i mean i want to interface with two systems using 1 FSB-PC, but each system using separate protocol.
junjun
Post by junjun »
No, cause every protocol have different configuration table.
hijazih
Post by hijazih »
i've attached a sample of the logical addresses
LOGICAL ADDRESS.CSV
(8.34 KiB) Downloaded 1224 times
hijazih
Post by hijazih »
Do any protocol sends ASCII data ???
junjun
Post by junjun »
here's are one sample for configuring Bacnet IP protocol.
sample.csv
(16.63 KiB) Downloaded 1258 times
