SIGA-PS near Halogen light
mikbz
Re: SIGA-PS near Halogen light
Post by mikbz »
Yes, you right the lights cause to faults and false alarms! You have 2 options or relocate the detector or lights( addition try to rotate the lights 180 degree, then the starter change it place and will decides you problem).
FVILLA
Post by FVILLA »
hijazih wrote:Dear All,
I have SIGA-PS installed near halogen light, it seems that the halogen is causing interference on the detector resulting in false alarm. Does anyone have an idea how to overcome this interference since there is no possibilty to relocate the detector??
Thanks in advance
hi heres the technical fax from EST on how resolving this problem.
regards...
Tech_Fax_No_110001.pdf
SIGA-PS, SIGA-PHS, and SIGA-IPHS Troubles and false
alarms
(85.14 KiB) Downloaded 473 times
hijazih
Post by hijazih »
Dear All,
Thanks in advance
