The EST3 panel can put its device into alarm via the keypad
http://www.thealarmtech.com/forum/viewt ... ?f=5&t=598
THIS IS A GREAT FEATURE
this only works with the 3-SSDC1 or 3-SDDC1 cards not the 3-SSDC or 3-SDDC
Via the keypad (under test) you tell the device to go into alarm the device then goes into alarm and responses back.
The LED on the device lights, because the device is in alarm.
The device has to be communicating for it to go into alarm.
I use this when I only need to test the response of the device.
I have only put Alarm devices into alarm, I have not activated supervisory
this may work for you. The device does go into alarm, but the element is not tested
SIGA-HRS Testing
Re: SIGA-HRS Testing
Thank you for your reply. It is not going to work for me unfortunately I have to make sure device can be heat activated.
hi, i use the SOLO testifire, ist a little overprice but works great.
http://www.testifire.com/site/home/
or you can use this too
http://www.solo-tester.com/site/products/heat_testing/
regards...
regards...
RADIOEXPORT wrote:I am looking for a tip on how to test SIGA-HRS heat detectors. Apparently you can not use magnet to activate them.
Currently I use 120V. electrical heat gun with extension cord and it is takes forever especially if you have hundreds.
I can not use SOLO kit it does not work for this type of heat detectors.
Can you guys give me an advise ?.
Thank you
Solo 461 will not test SIGA-HRS Works good for low profile detectors only
Not sure about Testifire.
SIGA-HRS Testing
Thank you
Thank you
