Hi All
I am in desperate need of assistance to set up the BACnet IP configuration for the EST to BMS communications bridge. I have gone through several different configurations but don't seem to be getting any closer to success.
I have attached the gateway export of the logical addresses from the SDU (points required highlighted) and the default config from the bridge. Any assistance would be greatly appreciated.
EST3 to BMS Communications Bridge
- 08-10-2017_BMS_DefaultConfig.csv
- (19.27 KiB) Downloaded 524 times
- 07-10-2017 FNB_DC2.CSV
- (6.34 KiB) Downloaded 534 times
Re: EST3 to BMS Communications Bridge
HI could you attach your sdu file I will work out and give you.
