Thank you for your replies, after a lot of work we gain access to the other 3030's and manage to upgrade all of their CPU's and SPAK's. Now the problem is that all of them are showing Software Mismatch. The all have NCM A and the NCA has NCM B.
Leo you mentioned that the LCM can be Upgraded via hardware, the system has more than 12 years funtioning, is it possible that even if we downloaded LCM firmware version 11, the LCM doens't recognize this firmware?
WE are doing all the upgrade with Verifire 9.0.
NFS Series Firmware/Application Code
Re: NFS Series Firmware/Application Code
What has the software mismatch ? What version are all of the panels? I'm assuming that you launcher spack 24 since you are using vft 9.0. This should have upgraded all possible firmware. I would go to each panel and hold the lamp test button, to see the software versions.
IT was a bad LCM, we have changed it and downlaod the LCM firmware again.
can anyone provide NFS2-3030 firmware application for version 26 or higher. I need to upgrade from version 18
Leo,
I Know it has been around 7 years since the last reply, But if its possible does swapping really solve the firmware issue? The Control Panel was compatible with V15 loop card but later it has failed & I'm wondering can I just swap the chip from the old one to new.
Additional to that any other method rather than using VFT to downgrade/upgrade?...... I do not have the license
