WinPak SE PE 3.0
GAETEN
Re: WinPak SE PE 3.0
Post by GAETEN »
If you need to put online the NETAXS-123 and 4 with the new Win-Pak 3.0 NETAXS Gateway template, you will need to upgrade the panel firmware, from 3.1.8 to 3.4.3, its a must.
NETAXS-123 will need a specific update for is firmware same for the NETAXS-2 and 4, so be carefull to choose the proper one.
Later on I will post the NETAXS Upgrade utility 1.1.10 to help with both firmware that will be needed to do the action successfully.
Gaeten
bvale
WinPak SE PE 3.0
Post by bvale »
WIN-PAK® SE 3.0 and WIN-PAK® PE 3.0 Now Available
L_WNPKINTD_D2.pdf
(1.27 MiB) Downloaded 784 times
L_WNPKPESEDV_D.pdf
(230.51 KiB) Downloaded 556 times
