WinPak- Service Pack 633.12
guest
Post by guest »
Attached are two SP service packs for winpak-pe/se/
------------------- readme.txt - in 633.10 ziped files -----------------------------
Note:
1> uncheck read only attribute of OpnDVRLib.dll on 'UI only' and complete installation of 633.2/633.7.1
2> If 633.10 is applied on 633.7.1 or 633.6 the batch file might show a message in command prompt that it was not able to modify a field to 'ntext'. This only means that the field is already of type 'ntext' and would have been so because of applying either 633.6 or 633.7.1 prior to 633.10. Hence this message can be ignored just by hitting <Enter>.
3> Check that all services are running after applying the patch and before starting WIN-PAK.
Servicepack 633.10 installs following modules on complete installation of 633.2/633.7.1
1>BackUpAndRestore.exe
2>DirectXVideoWrapper.dll
3>FusionAPI.dll
4>NCIArchive.exe
5>NCICore.exe
6>NCIResources.dll
7>OpnDVRLib.dll
8>TopazSignaturePad.dll
9>Winpak2.exe
10>WP Badge Def.dll
11>WP Schedule Service.exe
Servicepack 633.10 installs the following on 'UI only' machine
1>DirectXVideoWrapper.dll
2>FusionAPI.dll
3>NCIResources.dll
4>OpnDVRLib.dll
5>TopazSignaturePad.dll
6>Winpak2.exe
7>WP Badge Def.dll
Servicepack 633.10 installs following on 'DB server only' machine
1>NCIArchive.exe
2>NCICore.exe
3>BackUpAndRestore.exe
Scope of Servicepack 633.10
Includes 633.6 patch
Includes 633.7.1 patch
Has resolutions for these PCRs #1356, #705, #1428, #1452 and #1322
WP_SE_PE_PATCH_633.12.exe
(8.59 MiB) Downloaded 1184 times
WP_SE_PE_ServicePack_633.10.exe
(4.48 MiB) Downloaded 1150 times
