N-485-API Manual
N-485-API Manual
N-485-PCI-B connects to PC and panels rs485
N-485-API-2 mounts inside panel, converts current loop to rs485
N-485-HUB-2 Dialup modem
N-485-PCI-B - (win-pak PE switch 6 OFF) Switch 6 is the only which needs to be off
power cycle to update switch changes
panels can be set to 4800 baud and the computer can be 9600 baud.
Switch 6 on - you will be able to communicate directly to the panels via hyper terminal
WORKING IN HYPER-TERMINAL
check out this post
http://www.thealarmtech.com/forum/viewt ... p=444#p444
this device has been Replaced by the PCI3
N-485-PCI-B.pdf
(490.93 KiB) Downloaded 1452 times
CoolTermWin.zip
Terminal Emulator, good replacement for hyperTerminal
(1.56 MiB) Downloaded 525 times
